Off Delay Timers in Series
ER1990
Joined Oct 25, 2023
A customer of mine wants to start a sequence utilizing two timers in series once the "Wireless Controller" contact is closed. I did the logic in PLC but then the customer changed his mind when he found out how much it was going to cost for a PLC brick. So he asked if I can do a hardwire system. The sequence of operations is as follows: wireless controller contact is closed which then starts the off-delay timer #1 to energize a ball valve for 30 seconds. Once the 30 seconds is over, off-delay timer #2 needs to then start its timer for 5 seconds to energize the flush valve. I am stuck on how to make this happen with the hardwire system that's being requested. Any advice is appreciated. Timer.pngTimer Function.pngSchematic.pngPLC Logic.png
eetech00
Joined Jun 8, 2013
4,729
You can buy two programmable timer modules like shown below ($8 USD, Amazon) then daisy chain them together to create the sequence.
ER1990
Joined Oct 25, 2023
Hi eetech00,
Thank you for your help! One thing I forgot to mention is that the customer wants the ability to adjust the timer mechanically. That's why he asked for me to use the timers that I have on my thread.
Ramussons
Joined May 3, 2013
1,572
If you have the Hardware Timers, you need to include Relays that trigger the following Timers in sequence.
Timer 1 starts, at the end of its time, a relay is operated / released that powers the Second timer. And so on.
eetech00
Joined Jun 8, 2013
4,729
I think you have the wrong type of timers. They should both be "interval" timers.
From Omron:
"Interval Mode:
Operation in which the output turns ON as soon as an input is received and turns OFF after the set time. "
This operation would turn on the unit off after time out.
