Need old timers help: Need some sort of spring clip.
Tonyr1084
Joined Sep 24, 2015
9,744
Remember the days of TV's where they had knobs for changing channels and tuning into drifting stations? On the back side of the knobs, on the plastic that fit tight onto the tuner shaft there was a spring clip, round, that held the plastic tight to the shaft. What is that clip called? I need to find one. I have a bathroom exhaust fan that the squirrel cage keeps slipping off.
BobTPH
Joined Jun 5, 2013
11,647
I think I know what you are talking about, a C shaped clip in spring steel that into slots on the knob and grabs a slot in the shaft. No idea what it is called.
Found it C-clip.
eBay
External E Clips C Clip Circlip Retaining Ring M2 Upto M10 - 316 Stainless  Steel
But that will not work, the shaft and knob must be slotted for it.
28,253
What is missing from the request is a view of the shaft that shows the portion of the connection that couples shaft torque to the fan blade assembly. In some cases the motor shaft has a flatted section that is intended to lock with a flat area in the plastic blade part, which is hidden from view by the scale held over the opening.
Without seeing the shape of the shaft hat the blade is supposed to clamp on to, how can we guess at the correct choice???
The clamp shown by Mike in post #5 looks like a good guess.
Tonyr1084
Joined Sep 24, 2015
9,744
Spring hose clamp, constant tension hose clamp, spring band clamp.
This is what I'm looking for. Thanks
Those I know. It's supposed to clip into a slot on the motor shaft. There is no such slot.
Yeah, I know. I don't have the motor in my possession. It's on my client's work bench. He doesn't know how to solve the problem. If I had a picture of the shaft I'd have shared it.
Yes, it does have a flat. But the fan does not. The ID of the fan is circular, no flat. But it is a tight fit now. The clamp is insurance that the fan won't move around on the motor.
This is an exhaust fan mounted in the ceiling in a bathroom. If the fan should drift and jam up then the motor (in the ceiling can overheat) it could present a fire hazard. Doing it right is critical. I can't say this is "Right" but it's better than without the clamp.
Again, you're right. But MikeA has identified the clamp I'm looking for.
Fit the squirrel cage on to the motor shaft then take a photo so that we can see what you’ve got to work with.
I would have except I don't have the motor in my possession.
Tonyr1084
Joined Sep 24, 2015
9,744
And just placed an order for 10 of the spring clamps. Only need one but - - - . And I haven't had a need for anything like this since I was a teen messing with TV's (1970's)
Tonyr1084
Joined Sep 24, 2015
9,744
to prevent vibration.
Yeah, I'm considering that. But the fan speed is not very high. And given the mass is close to the center line there should be minimal imbalance. If bench testing shows too much vibration I can always grind the tabs off once the fan has been mounted to the shaft.
The clamps are close to what I want. Ideally they wouldn't have any tabs at all. And it's possible the clamp could be installed before the fan is mounted on the shaft "without tabs". Press fit the fan to the shaft. Should run pretty smoothly.
Tonyr1084
Joined Sep 24, 2015
9,744
The plastic at rest shows about 10mm. I ordered 8mm clamps. Hopefully it's not too tight to get on the fan or to press the fan onto the shaft. If not - I'll order either 9mm or 10mm.
35,171
FYI: The motor mounts from below the fan (as oriented in the pictures)
Does the retaining clip go on the front face of the fan (accessible) or between the fan and the motor (inaccessible).
I think if it is the latter, you will have difficulty getting the fan on to the shaft with a press fit.
I think weight imbalance will not be a problem.
