Time reversal of a signal in ltspice simulator
santlal
Joined Jan 14, 2020
12
I have a signal recorded in a .wav file. I want it to be reversed along time.
Please suggest how can I do it in ltspice.
santlal
Joined Jan 14, 2020
12
hi santlal,
Please post your wav file.
add .txt to the name so that site will allow an upload.
E
Hi ericgibbs,
I have wav file recorded in ltspice and I need to reverse it and use it in ltspice again. This recording, reversing and using it will be continue in a loop.
I am uploading wav file with .txt extension.
This audacity help in this type of computing?
Thank you.
ericgibbs
Joined Jan 29, 2010
13,881
hi santlal,
The wav file is only 48 bytes long, including the header.
Exactly what data is on the wav file.?
E
Header:
