Time based LED control from a button press
eetech00
Joined Jun 8, 2013
4,724
Yes I did. Discharges fully in under 2 seconds.
OK. I don't have one and didn't breadboard the circuit.
However, when simulating with LTspice, the timer doesn't trigger correctly (extremely short time ~180mS).
I tried different vendor BAT42 spice models but all work the same. The timer works correctly with 1N4148 or BAT54.
Anyway...that's the reason I asked.
sghioto
Joined Dec 31, 2017
8,751
Seems strange not working with a BAT42.
180ms is probably about right if the diode is installed backwards.
It definately works on the breadboard though.
See if you get the same results with this circuit.
LED should remain OFF until the button is held for 5 or more seconds.
eetech00
Joined Jun 8, 2013
4,724
It works if I use 1N4148 or BAT54, but not with BAT42.
I'll check the BAT42 models. Thanks for you help.
LewLex
Joined Jul 15, 2025
11
Transistor version with fast cutoff after appx 5 seconds.
i really like the simplicity of this one, so I'm going to get a sample board made from JLC. thanks for your suggestion
whilst i feel i've got an understanding of how it works, would Q1 not need a resistor between the base-emitter?
also, would this work for a higher power load, like a brushed motor pulling roughly 5A? with a suitably rated N-ch Mosfet
DickCappels
Joined Aug 21, 2008
10,661
The purpose of the resistor from the base to emitter is to assure that the transistor actually shuts off when it is supposed to be off. In the case of this very nice circuit, when the transistor is supposed to be off its base and emitter are shunted by the drain-to-source resistance of the MOSFET through R1 which is probably enough to keep the transistor's collector-to-base. leakage from turning the transistor.
