time activated relay.
agapis
Joined Feb 2, 2009
1
hi:
i have to design a undercarriage for a model hand launched glider for a competition.
the undercarriage must deploy AFTER 2 seconds, and the glider must remain airborn for at least 5.
heres the problem: it CANT use radio control.
so obviously a timer is the way to go.
i have the mechanical system designed, it just needs a timed actuator to pull the pin. once the pin is released the (torsion) spring loaded frame will deploy.
so i need a timed servo/rotary dc motor to activate after 2 seconds.
HOW CAN I DO THIS?
i have one real life 555 circuit built, and a simulated one in MULTISIM, but the output off the relay is showing decay on oscilloscope. it should be showing a square wave of a specified pulse witdth. it ISNT.
does anyone know ANYTHING about this kind of thing who can help me? i have spent many hours on google, and all the circuits seem to fail when simulated.
what i need a is a 5v-12v DC "monostable one-shot" circuit, that starts timing after i press a button, and either keeps the relay open for short/long enough to move my motor OR sends a correctly modified pulse (1.5ms) to my servo.
any ideas?
Wendy
Joined Mar 24, 2008
23,848
A simple 555 monostable will do the timing, but you need to figure out the mechanics from an electrical signal, also how you want to start the timing circuit.
