Hi.
I am using the Texas instruments INA125 chip for an analogue amplifier as I have shown on the attached image. INA125 data sheets says Nonelinearity -+0.002% of FS at Gain = 500
I am trying to use both the single and dual supply modes by connecting Vs- to ground or to a negative supply
The Dual supply operation seems to work fine (I have connected it almost identical to figure 1 of the INA125 data sheet) Its giving me an acceptable linear output 0.07% of FS for a gain of up to 4000.
The Problem is when I connect it in a Single Supply Mode (Figure 5 of the data sheet attached) with V-,VrefCom and IAref all connected to ground.
The linearity is way out of spec (I am getting 1-3% of FS) and I have a minimum Output of around 65mV (even placing offset adjustment resistors I cannot go below this value in single supply mode).
I also measured IAref before connecting it to ground at it was = 2.5V. A bit like in figure 6 of the data sheet, but how is this possible if I did not connect IAref to Vref2.5. I have a feeling watever the problem is, it probably has something to do with this IAref, but I cannot seem to know why..please help!
