Three stage Asynchronous counter design
ham3388
Joined Jul 3, 2012
97
I can see in table 1 that only the data under Qc of the truth table are used in all the colomns A, B, C and D but by one order ahead.
But I'm not understanding the logic.
Can you give a hint.?
RBR1317
Joined Nov 13, 2010
715
I don't understand the comment: "must be connected to gate logic for resetting at intermediate count"
I can understand a manual reset (pushbutton) or disable (switch) prior to the start of counting clock pulses. But what is the need for a reset otherwise? At what intermediate count would the logic need to reset the count?
ham3388
Joined Jul 3, 2012
97
I meant to say for example if you want to reset the counter at the count 4 then we can connect the desired Flip flops outputs to logic gates like NAND gates then the output of the gates to the CLR line.
RBR1317
Joined Nov 13, 2010
715
Q3, Q2, Q1 are logic inputs. A, B, C, D are independent logic outputs. You need to design the logic gate configuration individually for each output. There are four individual truth tables, there will be four separate Karnaugh maps. Note: some individual minterms may be reusable.
absf
Joined Dec 29, 2010
1,968
Let Q2=x, Q1=y and Q0=z;
Using the same table, can you make 4 equations describing A,B,C & D in terms of x,y,z?
Allen
ericgibbs
Joined Jan 29, 2010
21,552
hi ham,
The question asks for a PSpice sim, using 'D' type bi-stables [ flip/flops], NOT J/K types.
The attached image is for LTSpice, it should be enough to enable you to create your PSpice.
Regarding the 'D' logic output, note the state of 'q2' during the 0 thru 7 count [repeating sequence].
Draw up and post your PSpice version for us to check out
E
http://www.ee.surrey.ac.uk/Projects/CAL/digital-logic/gatesfunc/
ham3388
Joined Jul 3, 2012
97
Thanks again guys for guiding me.
Eric if you agree and if its not really necessary at this stages , we leave the PSpice simulation for later because I need some time to get some tutorial about using it.
How to make 4 equations to describe A,B,C and D in terms of Q1,Q2 and Q3 as was asked by Allen.
Can any one make only one just as an example?
ham3388
Joined Jul 3, 2012
97
One thing that I realised is that all the inputs to A, B and C are taken from Qc
with little adjustment. And for D all the exact outputs are taken. But still I'm not able to find the logic.
ham3388
Joined Jul 3, 2012
97
Look below I have attached the truth tabe of 4 stages counter, 4 bit.
Beside I put the denary numbers.
Table 1 Contin the benary numbers
0, 1, 3, 7, 15, 14, 12 and 8.
How from a 3 stage counter we can get the numbers 15, 14, 12 and 8.
I'm not understanding this?
WBahn
Joined Mar 31, 2012
33,114
I think you might be losing sight of the forest for the trees, or more accurately, are unable to focus on a tree because it is in a forest.
So try this problem (which is not directly related to your actual problem, but will hopefully help you see the approach that you need to take):
Design a logic circuit that outputs the implements the following truth table, where {A, B, C} are the inputs and Y is the output:
Code:
A B C | Y
0 0 0 | 1
0 0 1 | 0
0 1 0 | 1
0 1 1 | 1
1 0 0 | 0
1 0 1 | 1
1 1 0 | 0
1 1 1 | 0
ham3388
Joined Jul 3, 2012
97
I think I have understood up to some extent what you people are trying to say.
I made the following circuit based on your request.
I believe that 20160814_081826.jpg I need to make 4 similar ciciuts for A, B, C and D right ?
RBR1317
Joined Nov 13, 2010
715
FYI- My experience is that using index numbers helps cut down on transcription errors. You seem to have the correct logic expression, but an incorrectly labeled gate implementation.
