Three phase system question
Manuel Faria
Joined May 5, 2016
3
I have the following circuit. Three phase generator, direct sequence
The goal is to calculate i3.
I know that e3(t)=200sqrt2cos(wt)
C=1mF w=1000rad/s
P=10kW Q=10kVAr
P*=10kW Q*=-5KVAr
What I'm doing:
e1(t)=200sqrt2cos(wt-120)
e2(t)=200sqrt2cos(wt-240)
i3+i3'(capacitor)=i3''(load)+i3'''(load*)
i3'=V2(phase)/Zc
i3''=S/(sqrt(3)*VL)
i3'''=S*/(sqrt(3)*VL)
My doubt is in i3'' and i3'''
i3'=200sqrt2e^j(-240º)/j=283e^j(30)
i3''=10000sqrt(2)e^j(45)/sqrt(3)sqrt(3)200sqrt(2)e^j(30)=1,6e^j(15)
i3'''=11180e^j(27)/sqrt(3)200sqrt(2)e^j(30)=22,8e^j(-3)
Is this procedure correct? Thanks
32,840
Then you don't have much of a realistic choice but to assume that it is balance, but you should be sure to make a note that you are making that assumption.
32,840
Possibly. I'm just not willing to wade through your work unless you go back and track your units through the work properly.
