- Joined Jan 23, 2018
- 28,576
Indeed I did goof! I was intending response to the TS. The fact is that operating above the rated maximum voltage is asking for trouble. And changing over to a "Y" arrangement half wave supply from three phases is a simple revision. Leaving parts out is simple, adding the neutral may be a bigger deal .And stepping down from 400 volts to 9 volts just does not seem like the best plan.I think you quoted the wrong text. My response to the OP was not about capacitors.
I think there was a thread about doing that with resistors a short while back.
