Yes, I've run into that; an LM6134 in an amplifier that "burst into song" right at the positive peak of an output signal.The fact the oscillation is mostly on one slope of the triangle wave makes me think it isn't the op-amp. Unless, the op-amp bypassing is not good enough on one power supply. Have you ever seen an op-amp oscillate on only one edge of a transition?
