Thought process -- Thevenin problem
Doug Edmunds
Joined May 29, 2019
5
This is an Practice example from the Hayt/Kemmerley/Durbin Engineering Circuit Analysis. They ask to find the Thevenin equivalent and give answers of -502.5 mV and -100.5 Ohms.
I am trying to figure out the steps (thought process) to solve this problem with no success. Can someone walk through the steps they took to get this answer? BTW, this is self-study, not homework.
RBR1317
Joined Nov 13, 2010
715
But what could be simpler than Open-Circuit-Voltage & Short-Circuit-Current?
In the open circuit condition (V1=Voc) all the current flows through the resistor, so the voltage across the resistor is Voc-100 and the current through the resistor is 0.01·Voc amps. Then 0.01·Voc·20kΩ = Voc-100; Voc = -100/199
In the short circuit condition (V1=0) the current source supplies no current (because V1=0) so the current is Isc = 100V/20kΩ = 5 mA.
WBahn
Joined Mar 31, 2012
33,285
Don't make the problems harder than they are. Forget Thevenin, it is simply a circuit that needs to be analyzed.
It might help to put a box across the terminals so that it looks like the type of circuit your used to working with.
Now analyze it using either mesh current analysis or nodal analysis. Find the open circuit voltage by setting the right hand mesh current to zero and find the short circuit current by setting V1 to zero.
