Thought for the day...
18,150
The same can be said for probably most "ethnic" food categories. What we popularly think of as "Chinese", "Italian", or "German" cuisine is drastically different than what the people that grew up in those areas recognize as "home cookin'". It's usually much closer to "American" (whatever the heck that is, admittedly) than the original. I've often wondered what "American" cuisine tastes like in other parts of the world, but both my very limited opportunities to try it for myself and in talking with a handful of much-more-well traveled folks than me, I have the impression that it is a long shot from standard American fare, which is not to say that it can't be quite tasty.
I almost never bothered to find “American” food when traveling. Frankly I can’t recall seeing much of it anyway but I was always more interested in the local food. Anything aimed at Americans will be overpriced. The one thing you usually notice being absent is good big steaks. European menus will offer a 400g steak as the top end. How quaint! Of course you can find fast food and that usually cures any desires for back-home comfort.
o_O so pagers don't work in the same frequency/network as cell phones?
No, they don't as the modern US paging systems pre-dates cell phones by about 20 years. Most paging systems today are Satellite connected to a separate tower transponders so they bypass the phone cell tower linked system.
And other than transmitting to pagers, what do those tower transponders do?
Most are dedicated pager systems.
http://braddye.com/pagsys/pagsys.html
5.0 MICOR PURC
Motorola link transmitters are wire line control continuous duty FM transmitters. The transmitters have flat audio response and link keying is accomplished using HLGT. Once keyed, the link will remain keyed until audio activity has ceased. Upon loss of activity the transmitters will drop off the air. The drop out delay is adjustable and user set to 2,4, or 8 seconds. The transmitters are capable of generating Digital Private Line signaling to reduce problems due to co-channel users in the same geographic area. Digital Private Line, DPL for short, is a low speed sub-audible signal which represents a 23 bit binary word. DPL is used by a receiver as a qualifier for un-squelching. Not only must the receiver sense the carrier frequency but the DPL code must be continuously decoded for the receiver to pass audio. Motorola booklet 6881106E83 can be ordered for further detailed information regarding DPL.
  • Motorola offers link transmitters in the following frequency bands and power levels:
  • Midband: 72-76 Mhz, 30 watt and 125 watt models, Carrier Squelch or DPL
  • VHF 132-174 Mhz., 50-100 watts variable power out, Carrier Squelch or DPL
  • UHF 406-420 Mhz, 6-12 watt and 37.5-75 watt models, Carrier Squelch or DPL and 450-512 Mhz.,
  • 928-960 Mhz. band, 5-10 watt variable output, Carrier Squelch or DPL
Antenna connections to the link transmitters are of the UHF female type for all links except the 125 Watt Midband link. The 125 watt Midband Link is a hybrid station comprised of Micor control and low level RF circuitry with PURC 5000 power supplies and PA decks. The link transmitters are offered in a hot standby redundancy configuration in the event a failure occurs in the main station. Without a back-up unit a failure to the link transmitter would render the system useless until the link is repaired. It is strongly advised that systems be engineered employing hot standby configurations for link transmitters. Link transmitters are also available with battery back-up/charging operation in the event an AC power outage occurs at the site. The stations are also available with alternate AC power supplies for use in international markets. For servicing it is advised the links be ordered with a wattmeter and power and modulation alarm indication.
