Electrician,
Ratch
OK, I looked over the material you linked. One way subtracts the counter voltage and the other way Theveninizes the voltage sources. It appears to me that is a distinction without a difference. They both ultimately balance the current going into a node against the current leaving the node.Compare the details of the Branch method with the Node method, and you will see that Studiot is using the Branch method.
Ratch
