Hi All
This circuit that works, but it works inconsistently. I am hoping someone can tell me how to prevent this brown-out from occurring.
This circuit works in my car from 12VDC. Car Ground, Battery 12V and Ignition 12V is attached to this circuit.
What this circuit does ...
The 555 is activated by a momentary push button. Activates the K2 relay and delivers 12V out to external timer device. After this external timer is finished. It sends a Ground, or 12V, constant back to my circuit which activates the K1 relay. The K1 relay powers up multiple 12v external devices.
The problem ...
Once the 555 activates the K2 relay, It's only after the external timer device sends the 12v or Ground signal that this brown-out occurs. I am thinking the brownout is occurred when K1 relay is activate. So I tried putting the 'C2' 47uF 50V cap in the circuit in hope to maintain voltage IF that was the problem.
This brownout does also happen. I would say half the time it happens. BUT ... if I start this circuit with the key and NOT the 555 circuit. Then turn off the the key. And THEN activate the 555 circuit, everything works, no brownout. If everything is off and wait 15 or 20 minutes, then activate the 555 circuit. Sometimes it will work, sometimes there's a brownout.
TONY
The problem ...
TONY
