This circuit can't seem to work in simulators
Artem2018
Joined May 15, 2018
I was about to buy parts and solder them together, but I tried to simulate circuit first. None of the simulators doesn't do what they supposed to. Can somebody explain, is there an error in my circuit or simulators doesn't work?
dl324
Joined Mar 30, 2015
18,491
Welcome to AAC!
This sentence has two negations which becomes: All of the simulators do what they're supposed to.
Simulators need to know all component parameters before they can simulate. You're using a generic PNP and NPN transistor. What simulator are you using and how can it know what to do?
What do you think the circuit is supposed to do?
38,927
How can we determine why it doesn't work if you don't show us your results.
As dl324 said, put in real part number models for the transistors.
Then show us the full simulation schematic and results.
Artem2018
Joined May 15, 2018
Sorry, I don't know english very good. I'm not from english speaking country. I'll try to express my thoughts as good as I can.
I'm using multisim.
I think it suposed to charge capacitor with low resistance from transistors. Then when capacitor is charged transistors are closed and capacitor is discharging. This process creates Spikes signals on q1 transistor collector. I hope what i said was correct and understandable.
dl324
Joined Mar 30, 2015
18,491
Are you using a translator to translate your native language to English?
I'm using multisim.
I think that simulator will show devices being destroyed. Did it do that for this case?
If you drew the schematic more conventionally, you might be able to see issues more easily:
Ian Rogers
Joined Dec 12, 2012
1,136
I think this is supposed to be a siren circuit and the inductor makes up the rest of the oscillator... Other wise the circuit doesn't do anything!!!
