So I'm retro fitting a xbox 360 with a raspberry pi 3b+, I'm planning on running multiple os with the pie.
Iv connected my pie to a amplifier in the 360 housing and its picking up all sorts of noise. The amplifier is picking up every little bit of noise from everything and it's horrible.
Iv got a single 12v power supply power running everything 12v to the sata to usb to run the hdd and the 5v from the pie, 12v to the twin fan the original xbox fan, 12v feeding the amplifier, 12v to 5v feeding the pie and 12v feeding a few leds.
If I was to isolate the amplifier on its own power supply and have a ground loop isolate from the pie to the amplifier would this rid me of the noise.
The noise only appears when the pie is plugged into the amplifier via 3.5mm jack.
Or dose anyone have any other ideas as not really got the room for an additional power supply.
Thanks for any help
Thanks for any help
