Yeah I know , But I was taklking about that case only -____-
Thanks JoeJester for your concern.
My teacher in tech school told us that electrons are like lazy Boy Scouts- they will take the path of least resistance. He also said to consider resistors like mountains. The lazy Boy Scouts are hiking along, and come to a split in the path. One way is nice and level, the other goes over mountains. Which path will the (lazy!) Boy Scouts take? Correct! They will go hiking the easy way!Further I know when resistor is parallel with wire(short circuit ) the current through that resistor is equal zero , is it by somehow that is the reason the voltage through that resistor is equal to zero too!!) ....
im sure shes going to find this useful 5 months laterdear miss, have you read about kirchoffs voltage law!!! try applying it and you will end up with the answer. basically remember, current always tries to take a least resistance path in case of parallel resistors, and the short circuit is the least resistance path in your figure...
i would like to know what you think of it...
