The problems when Load Connect to Cockroft Walton Voltage Multiplier
Mars Park
Joined Feb 20, 2022
37
I made the Cockroft Walton Voltage Multiplier circuit (CWVM).
If the load was not connected, a voltage of about 500V could be obtained.
When the load was connected and powered on, the voltage was 9V. (I wrote RL as 100Mohms, but I'm not sure. )
When the power is oning, the output was 450V when the load was connected by the switch.
I want Case 3 without switch (450V of Output with Load).
What should I check? What's the problem?
Please give me some advice ,,,
Ramussons
Joined May 3, 2013
1,572
Voltage is measured between 2 points of a power source. In the above schematic, the 2 diodes and 2 capacitors form a Floating voltage source. A voltage has to be measured between 2 points of the source.
Point 1 is the junction of the cap and diode. The other?
It is like this:
1655879701603.pngWhat will the voltmeter show?
ps sorrry fot the terrible sketch!
Alec_t
Joined Sep 17, 2013
15,156
Atmospheric moisture and surface contaminants would probably lower that value considerably, unless you take precautions to prevent that.
What device is your load?
What did you use to measure voltage?
Mars Park
Joined Feb 20, 2022
37
It is like this:
View attachment 269980What will the voltmeter show?
Like this. The ground is common ground, which are primary's and secondary's.
Mars Park
Joined Feb 20, 2022
37
Load is a Photo Multiplier Tube (PMT). There are resistors to distribute the voltage to each pin of the PMT. The voltage measurement was simply done in a multimeter. And the multimeter's internal resistance will be 10M.
