The problem of Power Supply Current Regulator.
mahammadmahdi
Joined Aug 9, 2015
15
Hello dear SgtWookie:
when i make regulatur current before regulatur voltag(1-current 2-voltag). out put voltag change very slowly when time i turn potonsivmeter. but it is ok when replace two regulaturs. ( 1-voltag 2 -current)
what is your idea?
Mods edit :
This thread was split from here.
12,223
You need to pay more attention to the pinouts on the datasheets.
The diode bridge is connected to the rest of the circuit backwards.
You don't show pin numbers, but by your pictorial both 338's are connected incorrectly.
Your circuit to charge pump a negative voltage into the 7909 is incorrect.
The LM7909 is connected incorrectly.
What is the purpose of the component marked 117?
mahammadmahdi
Joined Aug 9, 2015
15
thanks of your idea
its circuit was design of data sheet lm338 for regulatur voltage and so regulator current . forgive me i dont wrote number pin . problem me in regulator current . but its circuit correct work now. and out put 7909 consider pin in data sheet is ok. negative pin 7909 is for regulatur current by lm117 but its dont work correctly.
