the primary phase voltage is ___ volts in the transformer.
Reloadron
Joined Jan 15, 2015
7,954
if i look at the secondary and see that their is 240V between L1 and L2 will that mean i can have a primary phase voltage of 480 volts?
Nope, looks like the mains transformer that feeds my house. You have, as mentioned a 30:1 turns ratio. Actually the numbers are realistic.
Ron
28,392
In an ideal transformer operated within it's design limitations, the voltage ratio is the same as the turns ratio. Thus, in the 30:1 turns ratio of the transformer in the sketch, the primary voltage is 30 times 240 volts, which is 7200 volts. There, I have done the math for you. It is not complicated. Transformer impedance ratios are more complex, but we are not discussint them here.
