I have always used the chrome ones (like the first one in your picture). I was just wondering what everyone else preferred and - specifically - why.Google LED holders and look at images. Lots available.
I use those also, as well as the socketed/replacable type, the one advantage with the socketed type they do not need the resistor, but are made for a specific voltage.I have always used the chrome ones . I was just wondering what everyone else preferred and - specifically - why.
No offense taken.There are hand nibblers available now. Puny useless pieces of useless crap. Did I say useless?
edit:
Apologies to nibbler lovers.
Sounds like you're too critical and have better eyesight than everybody around you, or you're rushing your work. Rushing to me means, foregoing a layout template, foregoing center punching before drilling, and drilling with a hand drill like you're 15 minutes past lunch time.Good ideas so far, thanks guys.
What hangs me up (almost every time) is drilling. I measure, re-measure, grid, cross-reference the grid with my measurements, and then drill. Small bits first, then larger bits to accommodate the size of the part. And the damn holes are still wonky. Even if they are off-axis only by an 1/16th of an inch it shows. I guess a drill press would fix this (that's my next purchase), but it gets OLD when you work so hard on a panel only to have three or four off-axis holes screw up the visual appeal of the whole thing.
What about power connections? Do you guys prefer to panel-mount female jacks or just run wire (with strain relief, of course) through a grommet?
Mine must be around someplace. Haven't run across it in years.No offense taken.
Yes, pretty awful devices. But they are useful for making small, square-ish holes is thin aluminum.
I bought one of the first hand nibblers ever made. I might still have the remains of the blisters to prove it.
I have one of these, http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=64823 As long as you have ~3/8" hole to start with it works real good. But like most of these kind of things they work better in aluminum and plastic then steel at the rated thickness. The company Aircraft Tool Supply has a lot of good sheet metal tools. At not too bad of prices compared to most places. The hand nibblers like the ones you guy's showed, are nothing compared to this one. I've had and used both.Mine must be around someplace. Haven't run across it in years.
So why doesn't someone make a big heavy duty one? I've looked!
Twice as big, even, would be useful. At 4 times I'm a buyer.![]()
Also, steel is a very bad conductor of heat compared to aluminum. Surprisingly, steel is only about 1/5 as good as aluminum.Altoid tin too thin to dissipate heat? Add a slab of aluminum on the inside of the box and bolt the hot part to that.
I hear you there. A drill press will just give you vertical holes, does nothing for wobbling off left or right.What hangs me up (almost every time) is drilling. I measure, re-measure, grid, cross-reference the grid with my measurements, and then drill. Small bits first, then larger bits to accommodate the size of the part. And the damn holes are still wonky. Even if they are off-axis only by an 1/16th of an inch it shows. I guess a drill press would fix this (that's my next purchase), but it gets OLD when you work so hard on a panel only to have three or four off-axis holes screw up the visual appeal of the whole thing.
