Yes it was connected to the 220 and everything worked fine, even without the grounded shield.Back in post #252 you said the circuit was working using the pot, was that with the 220 volts connected to the relay?
Excellent !!! I will try it now !I see from the video it was working. The problem is the sensing circuit.
Try adding the filter circuit seen in the schematic.
I've added your filter circuit and it definitely improved it.I see from the video it was working. The problem is the sensing circuit.
5more minutes, to produce and upload the movie.Probably can improve the filtering by adding a decoupling circuit comprised of R1 and C1.
I've added your new filtering components, decoupling circuit comprised of R1 and C1 , and is a bit more random when switching, pretty much like in the video. Im not sure if is better or worse. It seems a bit more random this time. It changed something, but I cant put my finger on it what exactly.Probably can improve the filtering by adding a decoupling circuit comprised of R1 and C1.
My metal table is linked to the ground (the green wire) that is now passing through all the extension cords in the room. My metal shield on the board, is connected to the table with a long wire as well. The contacts is as seen in movie. If I interrupt the grounding from the shield, all the leds are lighting, and everything goes to ON mode. Like everything is saturated and is open everything. When I connect the ground to the metal shield, then everything starts to function normally but with errors.Refresh my memory, how are you grounding the metal plate when on the wall?
The negative rail (0V) of the entire circuit, has no contact whatsoever with the grounded shield.I'm talking about the circuit ground, the negative connection on the circuit board to the metal shield..
| T | X-mas LED's fade on and off - OR - steady on. Which is better? | General Electronics Chat | 17 |
| Similar threads |
