Yes, now ,with no problems. Why "curious" ?Curious, using that signal amplifier module circuit does the green LED on the Relay module light up?
Correct.- I think the key was that capacitor for the trembling problem.
Yes. When that relay closes, it will open the 220V light bulb in my room. That is the reason for this project.What's up with Relay II circuit? You show 240VAC directly across the contacts.
Bravo, good idea, I had this idea myself as well and originally I planned to put the relay inside the round hole in my wall. But relay glued to the board.Can you move the Relay II module further way from the rest of the circuits?
Let me see what you got.Looking at your relay circuits you can eliminate Relay I and control the latch from the PC817 with a few modifications.
| Thread starter | Similar threads | Forum | Replies | Date |
| T | X-mas LED's fade on and off - OR - steady on. Which is better? | General Electronics Chat | 17 |
| Similar threads |
