I kinda of favor the pcb solution, if you have time. A small board in shrink wrap should work nicely. Do you use Eagle for your layouts? I would be happy to help with layout and checking, if needed.
Holes can be drilled without a drill press. If you can get the cheap phenolic board, not fiberglass, your drills will last much longer. Just use a HSS (preferred) or other steel bit, not carbide. I have done it with the bit held in a pin vise and rotated it with my fingers. There are not that many holes to drill.
John
John
