The impossible to ID LED display
eljefe
Joined Jul 3, 2020
Greetings,
Please accept my apologies for finding and joining your forum just to seek wisdom from people smarter and more talented than I am.
I am trying to repair a temperature controller with a bad 7-segment LED display. I am unable to identify the make/model or any data that could lead me to sourcing a replacement or specs that could aid in finding a compatible component.
Part number: XBWB2218T(GS)-A (no search hits on full or partial p/n)
Photo of display is attached. Any wisdom on the manufacturer and/or part is appreciated.
--Jeff
dl324
Joined Mar 30, 2015
18,329
Welcome to AAC!
We need more information.
How many pins does the display have?
Assuming the LEDs in the display aren't anything special, you just need to determine pin function, display polarity, and match the pin pitch, order, and display dimensions.
If the LED color isn't blue or white, you can use the diode check function on a DVM to determine electrical characteristics. With 4 digits, they probably multiplexed the digits to reduce pin count.
Hojaleaf
Joined Aug 23, 2020
Greetings,
--Jeff
Is this for a Masterbuilt smoker controller panel? I am looking for the same part. Except my part number stops after the (GS). If you find any info on this shoot me a message please. Thanks
