I am just starting electronic, I tought I was doing well until I came to this problem.
I absolutely want my led to be powered of my 6.1VAC - 5A transformer (other component runs from this tap).
I have this led :
http://www.cml-it.com/index.php?p=34&a=19270251&c=89
My transformer outputs 6.1VAC @5A (I don't want to use a bridge rectifier to get DC and power the led)
This led require 12VAC (+-10%) @9ma to light @60mcd.
IS IT CORRECT to assume that my led will run from my 6.1VAC transformer but will draw 18ma (double) to run @60mcd ?
OR the led will run from 6VAC but will still draw 9ma and run at about @30mcd ?
OR this will not even light the led ?
THANK YOU VERY MUCH I tried to find the answer alone but failed...
I have this led :
