Yes but i'm trying to test the "switching" of the transistor, how can i test the internal toggling and switching of the transistorIntermittent problems are most often bad or cracked solder joints. You can try heating or freezing the are to test for that.
That is not going to work. The change in base voltage is very small, and without a known load completely useless.If I tied a variable pot to +VCC and make a voltage divider and put the wiper on the base. I adjust the wiper of the pot until i find the threshold point of the transistor to switch states. I can monitor the switching state of the transistor using an analog meter or oscilloscope. The huntron has a DC generator so i can Enable the base to the transistor and monitor the switching off and on signature on the huntron.
If you can force the circuit the transistor is in to toggle it, you simply measure the voltage at the three terminals, starting with the collector (if it's a grounded emitter switch). It should be straightforward to determine if it's working correctly.Yes but i'm trying to test the "switching" of the transistor, how can i test the internal toggling and switching of the transistor
by Jake Hertz
by Duane Benson
by Aaron Carman
