Testing P6KE200A Transient Voltage Suppressor
UnnamedUser159
Joined May 3, 2016
501
I want to use the thread for asking something.
I measure diode p6ke200a out of circuit
I am using Resistance check method which i saw here
http://www.learningaboutelectronics.com/Articles/How-to-test-a-zener-diode
Anode-Cathode Diode Resistance Test
i see 19KoHms. is this reason to think that the diode is faulty? I read about the "right value" Hundred of KOhms but this is just 0.2 of hundred.
Cathode-Anode Diode Resistance Test
i see OL
thanks in advance
AlbertHall
Joined Jun 4, 2014
12,640
P6KE200A is not a normal diode and you won't get meaningful by measuring it with a multimeter (unless it happened to be short circuit, which yours isn't). It is a transient volrage supressor or TVS.
UnnamedUser159
Joined May 3, 2016
501
i just see zd number x and google "how to test zener diodes with multimeter"
Am i using the wrong method and why?
What is the correct way to test the diode?
