On the transformer it is center tapped on the secondary. The primary does have a 0-360-220 inputs. So not quite a center tap, just the ability to run off 360 and still get 14-0-14, I'm not even using the center tap on the secondary. I'm using it as 28v. I guess I could if I were using it in a half bridge setup but I kinda like the full bridge.
Okay I didn't think of that since his is voltage doubled. So let's just say it a full bridge. The cap are not there anymore, there are some but just for filtering. And then the 4.7uf DC blocking cap is there at the primary.
He talks as if it has only to do with his primary windings/inductance. He said in his write-up that he was pulling about 13 amps but when he decided to make his primary four inches instead of three and a half he was able to drop out one turn from 7 to 6 turns on his primary which up his current from 13 to 15. So theoretically is the inductance of the coil what portrays what amperage you'll be at? Do you happen to know how to calculate how much current you will have based on your inductance? Pretty much the same calculation as using a inductor as a choke. So what inductance will limit the current to what value?
