[Temporary solved] [Waiting for new parts] Need help for using INA122PA
LowQCab
Joined Nov 6, 2012
5,102
Before You buy new Chips ..........,
Connect "REF" to a 1K-1K-Resistor-Voltage-Divider, ( providing 1/2 of the Supply Voltage ).
I was surprised to see someone say that it should be connected to Ground,
and maybe that's standard practice, but I've never seen it done.
ericgibbs
Joined Jan 29, 2010
21,575
hi LowQ,
Ideally it should be a Low impedance Vref source voltage, but a quick and simple [ depending on the project] is a IN914 to ground, driven via resistor to +v, raising approx +0.7V
With a single supply, a Vref ground will give an approx +0.3v offset with a zero mV input.
Ground is OK with a dual power supply
E
LowQCab
Joined Nov 6, 2012
5,102
I'm just not so sure about those Chips having "Rail-to-Rail" Inputs and Outputs.
You never know what you'll get from China.
psamtam
Joined Dec 9, 2021
24
Just tried that
REF to GND = 1.777v
Output to REF = 2.67v
Signal = 0.00mv (shorted pin2 and pin3)
Power supply = 5v
unfortunately still does not work
AnalogKid
Joined Aug 1, 2013
12,280
The chip's input common mode voltage range includes GND. Also, there are single-rail circuits in the app section of the datasheet. Pages 8 and 9 in the October, 1997 version.
ak
ericgibbs
Joined Jan 29, 2010
21,575
Hi psam,
The problem with a single supply and Vref at 0V you get this result on the Vout.
ie: not 0v to 25mV , but with a +Offset voltage, to which the 0v to 25mV will be added.
What are you doing with the 25mV Vout signal.?
E
psamtam
Joined Dec 9, 2021
24
Hi psam,
E
25mV is for testing purpose since I don't have to connect Rg. My idea is: The more components I connect to a developing circuit, the more components to be diagnosis and debug.
After getting a working IC/circuit, I will put a VR across Rg and set it to 201ohm so that I can have a gain of 1000V/V and have a 5v output
and the current problem is:
whatever the output should be, the output now is always 4.4V when supply = 5V and Vref=0v
ericgibbs
Joined Jan 29, 2010
21,575
hi,
I think we all agree the INA122's you have are defective.
I would not agree with your logic about partly building this INA without the Rg.
For Testing place a 200R across Rg, this will be a more realistic Vout for testing the following circuits, it will also highlight any other possible problems in part of the circuit.
E
Update:
Note the non-linearity at the low levels of output.
psamtam
Joined Dec 9, 2021
24
hi,
E
oh great! I will place a 200ohm resistor across Rg.
Update:
Noted! thanks! <3
AnalogKid
Joined Aug 1, 2013
12,280
With Rg open, the circuit should have a gain of 5. I don't see that in #51.
My read of post #27 is that R2 - R5 in post #51 are not needed if the cell Vcc and GND and the circuit Vcc and GND are the same and connected. Do you have any other opamps available that are known to be good?
ak
tazea
Joined Nov 3, 2022
Hi, sorry to revive this post, were you able to fix the problem? Im having the same problem, same fixed output no matter what... Thinking on buying new amplifiers but in the meantime im trying to fix it
psamtam
Joined Dec 9, 2021
24
I gave up on using INA122p and I used three rail-to-rail op amps instead
