[Temporary solved] [Waiting for new parts] Need help for using INA122PA
Papabravo
Joined Feb 24, 2006
22,115
It seems like it might be a challenge to properly wire a circuit if you can't even draw a simple schematic with COMPLETE information. Circuits can not wire themselves.
ericgibbs
Joined Jan 29, 2010
21,622
Has no-one mentioned DC PATH TO GROUND?
I bet that the inputs need a dc path to ground to bias them up. Value doesn’t matter too much so long as it is much bigger that the resistance of the load cell.
hi,
It has a Load Cell connected to TB input terminals, it is a IA bridge amplifier.
E
sghioto
Joined Dec 31, 2017
8,758
What are the voltage readings on the load cell signal + and signal - ? They should read the same and be half of of the supply voltage without any pressure on the cell.
psamtam
Joined Dec 9, 2021
24
Sorry for bad drawing skills
hi psam,
I suspect you have the Load cell incorrectly wired, do you have a photo to post of the project.?
E
Here is the photos of my wiring and soldering. I have already checked **nothing is shorted accidentally**
Also, I have checked my load cell is functioning (0.0mv at rest, 2.0mv when I tried my best to bend it)
where
pin2: connected to load cell signal -ve
pin3: connected to load cell signal +ve
pin4: connected to load cell gnd
pin7: connected to load cell +ve
and pin6 is output
psamtam
Joined Dec 9, 2021
24
the load cell signal + to ground = 2.48V
the load cell signal - to ground = 2.48V
signal+ to signal- = from 0.0mV to 2.0mV (i tried my best to bend the 20kg load cell)
other information:
V+ vs V- = 4.97V
VO vs REF = 4.43V
ericgibbs
Joined Jan 29, 2010
21,622
hi,
Do these wires have colours.?
EDIT.
I do not see any printed Coding on that IC.????
psamtam
Joined Dec 9, 2021
24
hi,
Yes,
pin2 is the upper left yellow wire, connected to the load cell white wire
pin3 is the bottom left yellow wire, connected to the load cell green wire
pin4 is the grey wire, connected to the load cell black wire
pin7 is the white wire, connected to the load cell red wire
psamtam
Joined Dec 9, 2021
24
Should I buy INA122P/INA122PA from other site / shop to try again?
#33 is a clear closeup shot for the IC
Do you think my circuit is function? Should I try buying chips from other site / shop to replace the chip and see if it works? (p.s. I bought 3 INA122PA and they behave the same
AnalogKid
Joined Aug 1, 2013
12,287
See post #2. The problem is the input from the load cell, specifically a ground or some other DC reference for the amplifier. Let's back up.
How many wires are there coming out of the load cell?
What are their colors?
What are their functions?
If the cell has connection points rather than wires, how many are there?
How are they labeled?
Photos - ? Load cell website - ?
ak
psamtam
Joined Dec 9, 2021
24
I've been lurking. After only 13 posts, Ian nailed it in #14. The problem is the input from the load cell, specifically a ground or some other DC reference. Let's back up.
Photos - ?
ak
There are 4 wires coming out of the load cell
They are red, black, green, and white
the red wire is power input
, which could be from 5v to 10v according to the data from the dealer
the black wire is ground, which should be connected to the negative terminal of the power source
the green wire is signal +
the white wire is signal -
the load cell is functional, measured data is shown below:
V+ to V- = 4.97V
VO to REF = 4.43V
I was thinking the load cell is functioning correctly, but the chips or my circuit failed so that the voltage output is always 4.4V when input is 5V
psamtam
Joined Dec 9, 2021
24
Appears to be a defective chip. I have built that exact circuit and the normal output with no load on the cell is appx 100mv.
oh great I bought 3 defective chips for no reason!!!!!!!!!!!!!
That means I should try buying some more INA122PA from other sites / shop
Great thanks! <3
