KiCad, Temporary Connections (Monojacks), and "Pin connected to other pins, but not driven by any pin" errors
bignobody
Joined Jan 21, 2020
97
Hello!
I'm working on an audio sequencer circuit schematic in KiCad.
I have a bank of 6 audio oscillators, which I've individually connected to monojacks. I have a CD4051B switching through a selection of potentiometers, also wired up to a monojack. This is so I can use a patch cord to choose which oscillator I want to sequence.
Here's the idea, with a big red line representing where I might make a patch cord connection:
KiCad sure doesn't like this, though. Lots of "Pin connected to other pins, but not driven by any pin" errors, which all seem related to me using these monojack connectors everywhere.
Do I just ignore these errors, suppress them (somehow), or is there a way to let KiCad know my intentions here?
Thanks!
MaxHeadRoom
Joined Jul 18, 2013
30,605
Why do you want to include an external patch cord or connection cable etc if making a PC board, if just needing a schematic, you can draw what you like in KiCad.
Random Patch cord selections or external connections have no place in a schematic.
Of course it will error.
When does it "not like it"?
MaxHeadRoom
Joined Jul 18, 2013
30,605
I would have to replicate it.
I suspect it is because the connector has a pin designated 'Power' ?
If so you could copy the part and rename it and designate the pins as bi-directional or input, rather than power pin.
hrs
Joined Jun 13, 2014
525
The error usually has to do with power pins. Symbols like the CD4069 have multiple units, A B C etc. Unit G will be the power pins. Do you have it in the schematic and connected to power? Also put unused units on the schematic and connect unused inputs and outputs as appropriate for the IC.
I would not copy and modify parts but instead use power flags:
https://docs.kicad.org/5.1/en/eeschema/eeschema.html#power-pins-and-power-flags
If you run the debugger and click (or double click?) the error message, green arrows will appear on the schematic indicating where the debugger thinks there's a problem. This particular error could be ignored but then you're on your own in checking that everything is powered correctly.
ErnieM
Joined Apr 24, 2011
8,415
"Pin connected to other pins, but not driven by any pin" is typically safe to just ignore.
When a part is created each pin can have a defined type. The best example is a power regulator where one pin is a "Power In" type and another a "Power Out" type. Obviously you don't want to connect two "Power Out" pins together... or that may be just what you need to do.
Personaly I mostly use the "Passive" type as it connects to everything without a warning.
bignobody
Joined Jan 21, 2020
97
This is where I'm at. But I notice all the little green "problem arrows" are pointing to places that always connected to my mono jack connectors, so I guess I can just try to ignore them.
Thanks for the tips! Looking again these are technically "warnings" and not "errors", so perhaps I'm overreacting a bit... I'm still getting the hang of KiCad.
I mostly don't want to miss an important warning among the ones I think I can ignore, but I guess that all comes back to being careful.
MaxHeadRoom
Joined Jul 18, 2013
30,605
I could not find the exact socket you were using, all the ones in the edition I have had no live designated pins.
What you could do is assign it a power bus and place a appropriate power flag in order to satisfy the checker.
