Hi
has anyone observed the following effect?
In a circuit a gate driver (FAN73901) drives a halfbridge. Rgate are 15R. The high-side Mosfet reads 0R from gate to source. The resistance measured from driver output to the source reads 15R. Conclusion: The Mosfets gate is shorted to the source (internally).
After removing the Mosfet (with a lot of heat involved because it's mounted on an aluminum PCB) the Mosfet seems to be working fine. No short circuit on the driver output either. Put a new Mosfet in and the whole thing works, so it's like a temporary gate to source short circuit.
Obs: Deadtime had been adjusted too short so there was some 100ns cross-conduction when that happened. 180A peak. Anyway this was a 180A continuous current Mosfet.
