Yes it is a watch crystal only driving timer1. The MCU run on internal oscillator. The series resistance of a watch crystal is quite high. On the order of several Kohms, typical around 40Kohm. It is important, that care be taken to limit the drive to the crystal. Only a fraction of a mA of crystal current will damage this unit, causing it to stop oscillation.Maybe obvious for someone, but why R1 on the crystal? I have not seen that before.
Is the crystal recycled from a watch?
void lcd_format_and_send(void)
{ char timestr[3];
//lcd_clear();
lcd_goto(0x00);
lcd_puts("Klokken : ");
utoa(timestr, hour, 10);
if (hour<10)lcd_puts("0");
lcd_puts(timestr);
lcd_puts(":");
utoa(timestr, minut, 10);
if (minut<10)lcd_puts("0");
lcd_puts(timestr);
lcd_puts(":");
utoa(timestr, sec, 10);
if (sec<10)lcd_puts("0");
lcd_puts(timestr);
Please show your code that you use to setup the timer. The problem is most likely in there.That way i can time it ex by stopwatch, 10 sec and the circiut counts to 40. sec.
#include <htc.h>
//#include <stdio.h>
#include <stdlib.h>
#include "lcd.h"
__CONFIG (FCMEN_ON & IESO_OFF & BOREN_OFF & CP_OFF & MCLRE_OFF & PWRTE_ON & WDTE_OFF & FOSC_INTOSC);//XT
__CONFIG (LVP_ON & LPBOR_OFF & BOREN_ON & STVREN_ON & WRT_OFF);
#define LED RC0
#define _XTAL_FREQ 4000000
//global defs
volatile unsigned char week_day;
volatile unsigned char hour, minut, sec;
volatile bit timer_tick;
volatile bit blink;
const char * const day_of_week_names[] = {"Monday feels so bad",
"Tuesday feel better",
"Wednesday don't go ",
"Thursday goes slow ",
"Friday on my mind ",
"Saturday Night Live",
"Sunday be sporty "
static void interrupt
isr(void) // Here is interrupt function - the name is
// unimportant.
if(TMR1IF)
{// Was this a timer overflow?
TMR1IF=0;//Clear interrupt flag, ready for next
TMR1H=0x80;
//If we set TMR1 to start at 0x8000 (32768), the TMR1 will overflow every 1 second
timer_tick=1;
}//we are done here
void setup(void)
IRCF0=1;
IRCF1=0;
IRCF2=1;
IRCF3=1;//4MHz clock speed
//REGISTER 5-1: OSCCON: OSCILLATOR CONTROL REGISTER
// bit 6-3 IRCF<3:0>: Internal Oscillator Frequency Select bits
//1111 = 16MHz
//1110 = 8MHz
//1101 = 4MHz
//1100 = 2MHz
//1011 = 1MHz
//1010 = 500 kHz(1)
//1001 = 250 kHz(1)
//1000 = 125 kHz(1)
//0111 = 500 kHz (default upon Reset)
//0110 = 250 kHz
//0101 = 125 kHz
//0100 = 62.5 kHz
//001x = 31.25 kHz
//000x = 31kHz LF
TRISA0=0;
TRISC=0b01111000;//RC0-RC2 out,RC3-RC6 in,RC7 out
TRISB=0; //All port B output
GIE = 0; // Global interrupt disable just in case
ANSELA=0;
ANSELB=0;
ANSELC=0;//turn off all analog functions
//timer1 settings
TMR1H=0x80;
TMR1L=0;
//T1CON=0b00000110;//used during debug
T1CON=0b10001100;
// See datasheet REGISTER 19-1: T1CON: TIMER 1 CONTROL REGISTER
// TMR1CS<1:0> T1CKPS<1:0> T1OSCEN !T1SYNC TMR1ON
//bit 7-6 TMR1CS<1:0>: Timer1 Clock Source Select bits
//11 =Timer1 clock source is Capacitive Sensing Oscillator (CAPOSC)
//10 =Timer1 clock source is pin or oscillator:
//If T1OSCEN = 0:
//External clock from T1CKI pin (on the rising edge)
// T1OSCEN = 0:
//Crystal oscillator on SOSCI/SOSCO pins
//01 =Timer1 clock source is system clock (FOSC)
//00 =Timer1 clock source is instruction clock (FOSC/4)
//bit 5-4 T1CKPS<1:0>: Timer1 Input Clock Prescale Select bits
//11 = 1:8 Prescale value
//10 = 1:4 Prescale value
//01 = 1:2 Prescale value
//00 = 1:1 Prescale value
//bit 3 T1OSCEN: LP Oscillator Enable Control bit
//1 = Dedicated Timer1 oscillator circuit enabled
//0 = Dedicated Timer1 oscillator circuit disabled
//bit 2 T1SYNC: Timer1 Synchronization Control bit
//1 = Do not synchronize asynchronous clock input
//0 = Synchronize asynchronous clock input with system clock (FOSC)
//bit 1 Unimplemented: Read as 0
//bit 0 TMR1ON: Timer1 On bit
//1 = Enables Timer1
//0 = Stops Timer1 and clears Timer1 gate flip-flop
TMR1GE=0;
//T1GCON: TIMER1 GATE CONTROL REGISTER
//bit 7 TMR1GE: Timer1 Gate Enable bit
//If TMR1ON = 0:
//This bit is ignored
//If TMR1ON = 1:
//1 = Timer1 counting is controlled by the Timer1 gate function
//0 = Timer1 counts regardless of Timer1 gate function
//Timer1 Interrupt prepare
TMR1IE=1;// PIE1 register
PEIE=1; //INTCON register
PIR1=0; // Clear all bits PERIPHERAL INTERRUPT REQUEST REGISTER 1
//todo now in order to generate interrupt GEI=1 and TMR1ON=1
//setup LCD
lcd_init();
lcd_goto(0); // select first line
//set the globals
week_day=4;
timer_tick=0;
blink=0;
//other misc settings
timer_tick=0;//clear the tick
{ char timestr[3];
//lcd_clear();
lcd_goto(0x00);
lcd_puts(timestr);
lcd_puts(":");
lcd_puts(timestr);
lcd_puts(":");
lcd_puts(timestr);
// else lcd_puts("Next LED will be on ");
//lcd_goto(0x40); // Select second line
//lcd_puts("day of week ");
//lcd_putch(week_day+48);
// lcd_puts(day_of_week_names[week_day]);
// lcd_goto(0x00);
void main (void)
{ setup();
GIE=1;
TMR1ON=1;
while (1)
if (timer_tick)
sec++;
if (sec==60)
sec=0;
minut++;
if (minut>=60)
{ minut=0;
hour++;
if (hour>=24)
{ hour=0;
lcd_format_and_send();//send time to LCD
timer_tick=0;
//timer_tick=1;//just for debug
}// end if (timer_tick) Memo to my self put all this in sub function
}//end while endless loop
}//End main
I understood from the OP that the MCU is running with the XTAL. It is just running 4X faster than expected. More than likely it is timer initialization but I just do not have time right now to look at it.Let us do some basic checking. Do you have a LEDs connected on your board? I will first suggest a simple program running on the internal oscillator. Then just using the __delay_ms function to switch on and off a LED. This will check that the MCU is running on the clock speed we expect.
if(TMR1IF)
TMR1H=0x80;
T1CON=0b10101100;
T1CON=0b10001100;
First then you post something like this. You must also post something that explian your changes. It could be as easy as using copy and paste from the datasheetWhen i satinstead ofRich (BB code):T1CON=0b10101100;
i get a slower speed,Rich (BB code):T1CON=0b10001100;
takes now 40 real seconds to count 60 sec in chip.
if i change the TMR1H=0x80 to TMR1=0x80
80 real seconds to count to 60 sec in chip.
Why ??
#include <htc.h>
#include <stdlib.h>
#include "lcd.h"
__CONFIG (CLKOUTEN_OFF & FCMEN_ON & IESO_OFF & BOREN_OFF & CP_OFF & MCLRE_OFF & PWRTE_ON & WDTE_OFF & FOSC_XT);//INTOSC);//XT
#define LED RC0
//global defs
volatile bit blink;
"Sunday be sporty "
// unimportant.
if(TMR1IF)
TMR1H=0x80;
TMR1L=0;
timer_tick=1;
}//we are done here
void setup(void)
IRCF0=1;
IRCF1=0;
IRCF2=1;
//1111 = 16MHz
//1110 = 8MHz
//1101 = 4MHz
//1100 = 2MHz
//1011 = 1MHz
//1010 = 500 kHz(1)
//1001 = 250 kHz(1)
//1000 = 125 kHz(1)
//0110 = 250 kHz
//0101 = 125 kHz
//0100 = 62.5 kHz
//001x = 31.25 kHz
//000x = 31kHz LF
TRISA0=0;
ANSELA=0;
ANSELB=0;
//timer1 settings
TMR1H=0x80;
TMR1L=0;
T1CON=0b10101100;
// T1CON=0b10001100; //*4 speed
//If T1OSCEN = 0:
// T1OSCEN = 0:
TMR1GE=0;
//If TMR1ON = 0:
//If TMR1ON = 1:
//setup LCD
lcd_init();
//set the globals
week_day=4;
timer_tick=0;
blink=0;
{ char timestr[3];
//lcd_clear();
lcd_goto(0x00);
lcd_puts(timestr);
lcd_puts(":");
lcd_puts(timestr);
lcd_puts(":");
lcd_puts(timestr);
// lcd_goto(0x00);
void main (void)
{ setup();
GIE=1;
TMR1ON=1;
while (1)
if (timer_tick)
sec++;
if (sec==60)
sec=0;
minut++;
if (minut>=60)
{ minut=0;
hour++;
if (hour>=24)
{ hour=0;
timer_tick=0;
}//End main
Not that I think it matters, but in your void setup() you haveOk, try to remember another time,
Here is the complete code, that do not run at right speed.
Rich (BB code):#include <htc.h> //#include <stdio.h> #include <stdlib.h> #include "lcd.h" __CONFIG (CLKOUTEN_OFF & FCMEN_ON & IESO_OFF & BOREN_OFF & CP_OFF & MCLRE_OFF & PWRTE_ON & WDTE_OFF & FOSC_XT);//INTOSC);//XT __CONFIG (LVP_ON & LPBOR_OFF & BOREN_ON & STVREN_ON & WRT_OFF); #define LED RC0 #define _XTAL_FREQ 4000000 //global defs volatile unsigned char week_day; volatile unsigned char hour, minut, sec; volatile bit timer_tick; volatile bit blink; const char * const day_of_week_names[] = {"Monday feels so bad", "Tuesday feel better", "Wednesday don't go ", "Thursday goes slow ", "Friday on my mind ", "Saturday Night Live", "Sunday be sporty " }; static void interrupt isr(void) // Here is interrupt function - the name is // unimportant. { if(TMR1IF) {// Was this a timer overflow? TMR1IF=0;//Clear interrupt flag, ready for next TMR1H=0x80; TMR1L=0; //If we set TMR1 to start at 0x8000 (32768), the TMR1 will overflow every 1 second timer_tick=1; }//we are done here } void setup(void) { IRCF0=1; IRCF1=0; IRCF2=1; IRCF3=1;//4MHz clock speed //REGISTER 5-1: OSCCON: OSCILLATOR CONTROL REGISTER // bit 6-3 IRCF<3:0>: Internal Oscillator Frequency Select bits //1111 = 16MHz //1110 = 8MHz //1101 = 4MHz //1100 = 2MHz //1011 = 1MHz //1010 = 500 kHz(1) //1001 = 250 kHz(1) //1000 = 125 kHz(1) //0111 = 500 kHz (default upon Reset) //0110 = 250 kHz //0101 = 125 kHz //0100 = 62.5 kHz //001x = 31.25 kHz //000x = 31kHz LF TRISA0=0; TRISC=0b01111000;//RC0-RC2 out,RC3-RC6 in,RC7 out TRISB=0; //All port B output GIE = 0; // Global interrupt disable just in case ANSELA=0; ANSELB=0; ANSELC=0;//turn off all analog functions //timer1 settings TMR1H=0x80; TMR1L=0; //T1CON=0b00000110;//used during debug T1CON=0b10101100; // T1CON=0b10001100; //*4 speed // See datasheet REGISTER 19-1: T1CON: TIMER 1 CONTROL REGISTER // TMR1CS<1:0> T1CKPS<1:0> T1OSCEN !T1SYNC TMR1ON //bit 7-6 TMR1CS<1:0>: Timer1 Clock Source Select bits //11 =Timer1 clock source is Capacitive Sensing Oscillator (CAPOSC) //10 =Timer1 clock source is pin or oscillator: //If T1OSCEN = 0: //External clock from T1CKI pin (on the rising edge) // T1OSCEN = 0: //Crystal oscillator on SOSCI/SOSCO pins //01 =Timer1 clock source is system clock (FOSC) //00 =Timer1 clock source is instruction clock (FOSC/4) //bit 5-4 T1CKPS<1:0>: Timer1 Input Clock Prescale Select bits //11 = 1:8 Prescale value //10 = 1:4 Prescale value //01 = 1:2 Prescale value //00 = 1:1 Prescale value //bit 3 T1OSCEN: LP Oscillator Enable Control bit //1 = Dedicated Timer1 oscillator circuit enabled //0 = Dedicated Timer1 oscillator circuit disabled //bit 2 T1SYNC: Timer1 Synchronization Control bit //1 = Do not synchronize asynchronous clock input //0 = Synchronize asynchronous clock input with system clock (FOSC) //bit 1 Unimplemented: Read as 0 //bit 0 TMR1ON: Timer1 On bit //1 = Enables Timer1 //0 = Stops Timer1 and clears Timer1 gate flip-flop TMR1GE=0; //T1GCON: TIMER1 GATE CONTROL REGISTER //bit 7 TMR1GE: Timer1 Gate Enable bit //If TMR1ON = 0: //This bit is ignored //If TMR1ON = 1: //1 = Timer1 counting is controlled by the Timer1 gate function //0 = Timer1 counts regardless of Timer1 gate function //Timer1 Interrupt prepare TMR1IE=1;// PIE1 register PEIE=1; //INTCON register PIR1=0; // Clear all bits PERIPHERAL INTERRUPT REQUEST REGISTER 1 //todo now in order to generate interrupt GEI=1 and TMR1ON=1 //setup LCD lcd_init(); lcd_goto(0); // select first line //set the globals week_day=4; timer_tick=0; blink=0; //other misc settings timer_tick=0;//clear the tick } void lcd_format_and_send(void) { char timestr[3]; //lcd_clear(); lcd_goto(0x00); lcd_puts("Klokken : "); utoa(timestr, hour, 10); if (hour<10)lcd_puts("0"); lcd_puts(timestr); lcd_puts(":"); utoa(timestr, minut, 10); if (minut<10)lcd_puts("0"); lcd_puts(timestr); lcd_puts(":"); utoa(timestr, sec, 10); if (sec<10)lcd_puts("0"); lcd_puts(timestr); // else lcd_puts("Next LED will be on "); //lcd_goto(0x40); // Select second line //lcd_puts("day of week "); //lcd_putch(week_day+48); // lcd_puts(day_of_week_names[week_day]); // lcd_goto(0x00); } void main (void) { setup(); GIE=1; TMR1ON=1; while (1) { if (timer_tick) { sec++; if (sec==60) { sec=0; minut++; if (minut>=60) { minut=0; hour++; if (hour>=24) { hour=0; } } } lcd_format_and_send();//send time to LCD timer_tick=0; //timer_tick=1;//just for debug }// end if (timer_tick) Memo to my self put all this in sub function }//end while endless loop }//End main
TRISA0=0;
T1CKPS1 = 0; // bits 5-4 Prescaler Rate Select bits
T1CKPS0 = 0;
T1OSCEN = 1; // bit 3 Timer1 Oscillator Enable Control: bit 1=on
T1SYNC = 1; // bit 2 Timer1 External Clock Input Synchronization Control bit: 1=Do not synchronize external clock input
T1CONbits.TMR1CS = 0; // bit 1 Timer1 Clock Source Select bit: 0=Internal clock (FOSC/4) / 1 = External clock from pin T1CKI (on the rising edge)
TMR1IP = 0; // Timer1 is low priority interrupt
TMR1IE = 1; // Enable interrupts for Timer 1
TMR1CS1=1; //CLOCK SOURCE SELECTIONS
TMR1CS0=1;
//If T1OSCEN = 0:
//If T1OSCEN = 1:
// <1:0>: Timer1 Input Clock Prescale Select bits
T1CKPS1=0;
T1CKPS0=0;
T1OSCEN=1;//LP Oscillator Enable Control bit
nT1SYNC=1; //: Timer1 Synchronization Control bit
TMR1ON=0;//: Timer1 On bit
TMR1H = 0x80; // preset for timer1 MSB register
TMR1L = 0x00; // preset for timer1 LSB register
