So, im new here, but can i ask for some help on my project, so i want to controll the temperatures of my 5 band mica heaters about 150 watts each, so i orderd a wattmeter and a temperature sensor type K, im on a very tight budget and i im thinking if i can use voltage regulator board with a potentiometer to give a certain amount of voltage to the band heaters, i don't know alot about electronics just some basic ones,so ill first use a wattmeter and temperature sensor to know the power one band heater will be at 220 deg. celsius max using the voltage regulator then ill do the same for every band heaters, am i doing the right thing? thank you in advance
this is for the voltage regulator : https://shopee.ph/2000W-25A-50-220V...ator-with-External-Knob-i.41810948.5832693517
this is my band heaters : https://shopee.ph/product/116459846/2758097546
my temperature sensor : https://shopee.ph/product/195021369/6819991266
my wattmeter : https://shopee.ph/product/82576541/1447654029
