Can u provide ma a circuit diagrm and explanation.
Ok thank u
No.Is there any idea to control speed of fan on this circuit
Any other circuit..
What size is your motor? Voltage/amp rating. Simple motor or gear motor?Any other circuit..
Use an Lm35 with a Window comparator, set it to 250mV low 300mV high, that will give you two outputs...25° C turn on
25°- 30°C half
35°C above full speed
It will be a lot easier with an op amp between the LM35 and the transistor. Or even using Pulse Width Modulation (PWM) to control the transistor - especially if you add a micro controller.Ok I will try it thanks
