Temperature control of a heater cartridge
Amanullah Tomal
Joined Sep 8, 2016
5
Hi, I am a student. I have a low basic in electronics and circuits,
I need some help for making a circuit to control temperature of a heater cartridge.
I have the following things
Cartridge heater Voltage: 12V power 40W
Thermistor:NTC 100K B=3950
I want to control temperature using NI USB 6211
Please help me making the circuit and wiring. If i need to buy any thing please suggest me.
#12
I have a thermistor thermostat laying around, but the USB I don't. Here's a datasheet for the requested interface:
Amanullah Tomal
Joined Sep 8, 2016
5
I want help regarding wiring and making circuits. For circuit should I buy anything like Relay/ MOSFET. I have just got some ideas but not sufficient.
Amanullah Tomal
Joined Sep 8, 2016
5
Your circuit could be based on something like this :-
Hi Alec_t,
Thanks a lot for your reply.
Plese clarify me the following things, in USB6211 you have shown A & D here A= ANALOG INPUT
D= DIGITAL OUTPUT/PWM right???
2. +5V will come from USB 6211 right??
3. what is Trim?
4. There are 3 pins for N- MOSFET. Gate, Source and Drain
Please elaborately tell me only about these 3 pins connections.
5. will you suggest me which N- MOSFET will be suitable for my application?? is there any model number?
Amanullah Tomal
Joined Sep 8, 2016
5
Hi Alec_t,
3. what is Trim?
6. Another thing I want to keep the temperature constant at 200C. For this one should I need anything more??
Alec_t
Joined Sep 17, 2013
15,160
A= ANALOG INPUT
Right.
No. From the USB bus. According to the datasheet the USB6211 is "bus-powered".
what is Trim?
A trimmer potentiometer wired as a rheostat, to allow setting of the input operating point if need be.
Yes. The pinout depends on the particular FET you choose/ can obtain where you live.
Don't know your component source. Do you buy locally or on-line? Can you access Farnell, Digikey, Mouser, .....?
Amanullah Tomal
Joined Sep 8, 2016
5
Right.
I buy from the both of the sources that means locally/ online. I can access DIGIKEY.
