Hello! I have a project that involves a teensy 3.2 and a BLE HM-10 module.
I actually need to wirelessly connect a myo armband to my teensy microcontroller through HM-10.
I successfully connected the said components but it is through an Arduino UNO and not teensy. However, I need to use a teensy board and not an Arduino.
Here is the code:
In Arduino, I simply connected the TX Pin of HM-10 to Pin 2 of Arduino and connected the RX Pin of HM-10 to Pin 3 of Arduino.
I did the same connections on my teensy board. But I had to add this part on the code "while (!Serial) ;" to display a text on the serial monitor.
but its stuck on "Searching on myo…" but in Arduino it will display "connected"
Through my research.. I think that it has something to do with SoftwareSerial but I'm not really sure. Also, maybe pin 2 and 3 are not the right pins to connect the Rx and Tx of the HM-10 when it comes to teensy 3.2??
I'll really appreciate your help guys.
Thank you so much!
Here is the code:
Code:
* @file printFirmwareInfo.ino
* @author Valentin Roland (webmaster at vroland.de)
* @date September-October 2015
* @brief Example file demonstrating connecting to and reading data from the Myo.
* This file is part of the MyoBridge Project. For more information, visit https://github.com/vroland/MyoBridge.
* @include printFirmwareInfo.ino
#include <MyoBridge.h>
#include <SoftwareSerial.h>
//SoftwareSerial connection to MyoBridge
SoftwareSerial bridgeSerial(2,3);
//initialize MyoBridge object with software serial connection
MyoBridge bridge(bridgeSerial);
//a function to inform us about the current state and the progess of the connection to the Myo.
void printConnectionStatus(MyoConnectionStatus status) {
//print the status constant as string
Serial.println(bridge.connectionStatusToString(status));
void setup() {
//initialize both serial connections
Serial.begin(115200);
while (!Serial) ;
bridgeSerial.begin(115200);
//wait until MyoBridge has found Myo and is connected. Make sure Myo is not connected to anything else and not in standby!
Serial.println("Searching for Myo...");
//initiate the connection with the status callback function
bridge.begin(printConnectionStatus);
Serial.println("connected!");
Serial.print("Firmware Version: ");
Serial.print(bridge.getFirmwareMajor());
Serial.print(".");
Serial.print(bridge.getFirmwareMinor());
Serial.print(".");
Serial.println(bridge.getFirmwarePatch());
Serial.print("Hardware Revision: ");
Serial.println(bridge.getHardwareRevision());
//declare a storage array for the hardware address
byte address[6];
//get the address and store it in our array
bridge.getHardwareAddress(address);
//print the hardware address in HEX format
Serial.print("Hardware Address: 0x");
for (int i=0;i<6;i++) {
Serial.print(address[i], HEX);
Serial.println();
//get the unlock pose
MyoPose unlockPose;
unlockPose = bridge.getUnlockPose();
//print the name of the unlock pose as string
Serial.print("Unlock Pose: ");
Serial.println(bridge.poseToString(unlockPose));
//get the current battery level and print it
byte batteryLevel = bridge.getBatteryLevel();
Serial.print("Battery Level: ");
Serial.println(batteryLevel);
//short vibration to show we are ready
bridge.vibrate(1);
void loop() {
//update the connection to MyoBridge
bridge.update();
Thank you so much!
