Yes, I saw the video. I think that is more of a function of the time base you selected. That frequency is much greater than the 1.2 mS of your full display. You would have to increase the time base a couple of steps higher to see more of that signal.Okey... i just thought it was strange the trace suddenly started to jump...also under the "center" line.. did you see the video?
I believe he got the new batch from digikey .... I could be wrong though.Transistors that burn out on higher power demand can also be a sign of bad components.
Where do these output transistors come from?
Thanks, i will check the area.Check the condition of the component welds in the area indicated in red on the attached capture.
A break in the link could cause the amplifier to "excite" and lead to the destruction of the output transistors.
Yes it was...Was the speaker selector switch turned to OFF when you set the ICQ?
| Thread starter | Similar threads | Forum | Replies | Date |
| A | Technics SU VX-800 with blown components (another one) | Technical Repair | 139 | |
| T | Technics SU-V450 not powering up properly | Technical Repair | 1 | |
| K | Request for help in repairing Technics SU-V90D | Technical Repair | 126 | |
| R | Technics SL-PJ1 CD player | Technical Repair | 53 |
