The obvious test, replace it and test the results.Just did a little research...I took Q421 and Q425 out of circuit.
Q415 tested OK.
Q421 did not test OK !
Could this be the culprit? hmm
Q415 tested OK.
That did not hold true for Q429 where the emitter and the base were the same (within the count error of the meter).Besides the base and the collector of Q421 indicated the same value, so if it is the junction was short-circuited.
I know, and I mentioned the same condition (where the base voltage and another voltage, e or c, was the same) did not hold TRUE for Q429.I did not speak of the transistor Q429, but of the Q421 which had its base and its collector at the same value.
Probably a shorted junction.
This is exactly how I have been troubleshooting for the past 15 years. It is very difficult. I have had to be on-site for problems that were too complex for timely remote troubleshooting, but as time passed and my techs developed their skill level, my on-site time was reduced.@CBTech_Joe you will find this type of troubleshooting challenging. Reminds me of when the only troubleshooting I did was in my head relying on my technicians to provide what they were doing when they were troubleshooting, or in some cases, learning to troubleshoot and expand their experience base.
Every problem that caused us to have production interruptions was thoroughly reviewed and debriefed to find out what we did wrong as well as what we did correctly and how we could have avoided those mis-steps. Afterwards the best methods we could have used were documented and put into our equipment notes. This was not done at the management level (where I would give a very basic review) but with all the technicians in the shop.As a case study, this one, once completed, would require a review on all the steps and mis-steps, to try and mitigate the mis-steps. The best learned experience comes from the mis-steps.
Out-briefs are always written by the technician, the others hear the story and hopefully gain some insight. And this thread here is one story.This was not done at the management level (where I would give a very basic review) but with all the technicians in the shop.
Yeah, it's looking like that.This isn't an easy fix
Still, we start somewhere. Remember, we had a number of components out of the circuit before the failure. Did you happen to check them before re-installing them?Seems like something that’s hard to find is defective...
yes..my tester says no goodWhat does BLOWN mean? I realize it means NO GOOD, but let's get down to how they failed. SHORTED (b-c, b-e, e-c) OPEN (b-c, b-e, e-c)
In lieu of waiting for those components, try to get the substitutes for them that are locally.
Thread starter | Similar threads | Forum | Replies | Date |
Technics VX800 Extended Drive No Sound?? | Technical Repair | 30 | ||
Technics SU-VX800 amplifier parts availability | Technical Repair | 3 | ||
M | Technics current drive problem on a vx800 | General Electronics Chat | 6 | |
B | Technics SU VX800 Amp Problem | General Electronics Chat | 4 | |
Technics SU-VX800 Repair Help | General Electronics Chat | 13 |
by Duane Benson
by Jake Hertz
by Duane Benson
