I have sound on both channels . Thank you so much for your help!!Work on one channel at a time.
Install the power transistors. Measure output DC voltage. If the voltage is zero only then connect the loudspeaker. Input a music source and play at low volume levels. If all is well do the same with the other channel.
The show is not over till the fat lady sings, in other words, when there is music to your ears.
| Thread starter | Similar threads | Forum | Replies | Date |
| A | Technics SU VX-800 with blown components (another one) | Technical Repair | 102 | |
| T | Technics SU-V450 not powering up properly | Technical Repair | 1 | |
| K | Request for help in repairing Technics SU-V90D | Technical Repair | 126 | |
| R | Technics SL-PJ1 CD player | Technical Repair | 53 | |
| S | Technics SU-V5 won't turn on (2) | Technical Repair | 4 |
