take me to a world that has 90k resistors
badbaud
Joined Mar 5, 2009
26
I have tried all of the major distributors for a 90k 1/4w 1% resistor and no one has responded. Metal film or foil or wirewound, I don't care.
Does anyone know of a source for these resistors, I need 100 right away for a project.
t_n_k
Joined Mar 6, 2009
5,455
Or take 22kΩ+68kΩ in series. They would need to be 0.5% tolerance to meet the 1% tolerance requirement. Ditto for the parallel case as well.
Adjuster
Joined Dec 26, 2010
2,148
I don't see the need for two 0.5% resistors to get a 1% tolerance combination. Combining resistors of a given tolerance in series or parallel gives a result of the same tolerance worst-case. In fact, the statistical distribution of the combined result tends to be tighter, as to obtain a worst-case result requires two devices to be at their tolerance limit.
It is true that the worst-case percentage tolerance error given by a large ratio potential divider can approach double that of the resistors it is made from. That can be relevant if you are making something like an attenuator.
wmodavis
Joined Oct 23, 2010
739
It is a good thing for designer and/or hobbyist to be aware of and take into consideration 'standard' values for components to save from having to undergo your type of frustration. What if there were no standard values that could be manufactured and readily available. And of course as has been pointed out in the above responses, it is also a good thing to be familiar with the myriad of ways to get intermediate values when it imperative to have one. And IMO a third good thing is to know how to recognize whether it is in fact imperative or not.
tom66
Joined May 9, 2009
2,595
Not necessarily true. Read this thread. Combined resistors of 0.1% tolerance can give up to 0.2% error worst case!
KJ6EAD
Joined Apr 30, 2011
1,581
An older technician I knew told me that they used to file away part of the element on large carbon composition resistors to adjust them up in value.
Adjuster
Joined Dec 26, 2010
2,148
Yes, but that is precisely the division ratio error issue that I referred to in the second part of my post. You can indeed get a divider ratio error percentage approaching the sum of the two resistance tolerance percentage errors, but that is not the same situation as building a single composite resistance.
strantor
Joined Oct 3, 2010
6,875
Ok, I don't see how you can add the 2 percentages. practical example:
I want a 600Ω resistor ±1% but all I have are (2) 1.2KΩ ±1%
So, 600 + 1% (worst case) = 606Ω
and, 1,200Ω +1% (worst case) = 1212Ω
I parallel the (2) 1212Ω resistors and I get 606Ω - That's still 1%.
Actually I would think that you would have a better chance of hitting your mark by parallelling resistors because, unless both are at the max tolerance, one should pull the other closer to the correct value.
EDIT, ok I see that you are talking about 2 different resistance value. never mind
#12
By the way, The principle of the 9.1 meg resistor in parallel is that it is about 100 times the needed value, so its 5% tolerance could only affect the final product by .05%
PackratKing
Joined Jul 13, 2008
847
I have a bad habit ?? of putting an X fixed resistor parallel across an X trimmer pot, and dialing in what I actually need.
It might look a little odd and cobbled, though it certainly works. Nailing the tolerance needed can be tricky, since the little trimmers are none too tight.
It helps to have a shoebox full of trimmers..............:D
Ron H
Joined Apr 14, 2005
7,063
We should be asking Badbaud why he needs a 90k resistor. There is frequently another solution if the big picture is seen.
