synchronous circuit
lidor250
Joined Oct 2, 2021
6
Hi!
I'm trying to design a synchronous circuit which its functionality is- when the input (one bit each clock cycle) is 1 - the output is 1 for N clock cycles.
during those N clock cycles it doesn't matter what the input is.
what is the simplest way to do it?
I tried to do it by a counter which counts to N and then resets and stops itself, but it didn't work entirely.
thanks everybody :)
Ian0
Joined Aug 7, 2020
3,757
This is homework help, so I'm offering hints, not the complete answer.
Assuming that N is small, then how about an N-stage shift register, and a JK flipflop (if it didn't have to be synchronous, then set-reset would have done)
First output of the shift register to J, Nth output to K. Nth output also clears the shift register.
lidor250
Joined Oct 2, 2021
6
Thank you for your help.
Thought about N shift register, but I can't assume N is small, so that kind of solution would be inefficient.
dcbingaman
Joined Jun 30, 2021
497
Hi!
thanks everybody :)
It sounds like input is not synchronized to the clock? Be sure to send the input to a register first to synchronize the input to the clock. Otherwise you risk metastability.
