Design a synchronous counter flip flop
MStafashabaan1212
Joined Apr 15, 2020
Design a synchronous counter counts the sequence of your ID number from left to right. ▪ Your full identification number (each number separately) is displayed on a seven-segment unit for a second, so that the first four numbers are displayed through the counter and then the rest of your number is displayed. ▪ During the display, the fourth number from the left will be recognized in your ID (to define the year you join the academy) by means of a decoder that gives an alarm (Buzzer tone) for 4 seconds and then completes the display of the rest of your number. ▪ Each number is displayed on a seven segments unit for a second, the clock must be designed to has a periodic time of 1 second ▪ The design recognizes if your number is odd (a green LED lights up) or even (a yellow LED lights up). ▪ The design decides if the year of joining the academy before 2018 (then lights up a blue LED), or if 2018 and beyond (then lights up a red LED).
dl324
Joined Mar 30, 2015
18,476
Reformatted post to make it easier to read.
