Hello, I am attempting to wire a SwitchPros 9100 to drive a linear actuator on my Chase rack, I have read many things on these forums but am completely lost on what is being said without + - Signs etc. the SP9100 uses SPST type switches with solid state relays to control everything. The linear actuator uses a Postive signal to extend and a Negative to retract. I have attempted to use a relay to retract the actuator but to no avail. 86 Input from the SP9100 which is a positive line when actuated. 87/85 Jumped together to a ground, 30 being output which is pushing out ~-12vdc (verified with multi meter). I have the 30 output being attached to the + line on the actuator which is what Switch Pros is telling to me do but I am getting no reverse drive on the motor. I can extend the motor if needed when pressing the up button to drive it up and send the +12vdc to the motor. If I hook up the DPDT rocker switch to the motor with the way they say to wire it I can drive the motor all day long but do not want to drill into my dash to use that switch. Can anyone please help with how to wire this thing up?
