switching state of a NC output to NO with a relay
nadeemchughtai
Joined Dec 18, 2019
7
I have a NO/NC switch and I close it it get a NC output. When I get a another NC input from another device, I would like the first NC switch output to go open. Can anybody please help please. I can do it with an arduino board but I was looking for a possibly using a relay?
35,278
Get a relay that has double-throw contacts.
Wire your first switch to supply power to your new relay.
Now you have a double-throw switch to choose as you please.
strantor
Joined Oct 3, 2010
6,875
Can you re-word this? I cannot understand what you want.
nadeemchughtai
Joined Dec 18, 2019
7
I have 2 dry contact inputs, Input 1 has no voltage open or closed , input 2 has 12 volts when open and 0 volts when closed. I would like the following results:
Input 1 Input 2 Output
open open open
open closed open
closed open closed
closed closed open
Can I possibly use a relay with Input 1 being a SPST switch?
nadeemchughtai
Joined Dec 18, 2019
7
Will this work with the following requirments:
open open open
open closed open
closed open closed
closed closed open
nadeemchughtai
Joined Dec 18, 2019
7
Will this work for the following requirements:
open open open
open closed open
closed open closed
closed closed open
eetech00
Joined Jun 8, 2013
4,744
Can you provide a part number or schematic of the switch, or switches, so we know exactly what were working with?
GetDeviceInfo
Joined Jun 7, 2009
2,285
open open open
open closed open
closed open closed
closed closed open
Only the device and its intended operation could tell you what happens when it receives an input on its dry contact input. What constitutes your output?
