panic mode
- Joined Oct 10, 2011
- 5,399
what is the load current? using SPDT means one of the switches would need to handle current of both loads.
If you wire it like I've shown in post #6, you can use any low voltage/current SPST switch and a standard automotive relay.If the mini switch is rated at 3A 250VAC, does that mean on 12VDC it technically should be able handle higher than 3A? Although combined both my LEDs are probably less than that
The current rating of a switch is related to the contact resistance and the resultant heating effects, so it is rather independent of the voltage. The voltage rating is related to the contact spacing in the open condition, and the insulation. It is also affected by the sparking when the switch opens under load.If you wire it like I've shown in post #6, you can use any low voltage/current SPST switch and a standard automotive relay.
In my post, the switch is controlling the relay (like it should be anyway), not the load directly.The current rating of a switch is related to the contact resistance and the resultant heating effects, so it is rather independent of the voltage. The voltage rating is related to the contact spacing in the open condition, and the insulation. It is also affected by the sparking when the switch opens under load.
For a switch that is not opened or closed with the power on and current flowing , the current rating will be the same, no matter the voltage.
Hi eetech00,If you wire it like I've shown in post #6, you can use any low voltage/current SPST switch and a standard automotive relay.
DRL lights don't need to be manually turned on (at least not on my vehicle).Wired as per post #6, both front and rear lights will be on even without the relays being energised.
Nandu.
