Switching High Voltage Low Current
Metalfan1185
Joined Sep 12, 2008
185
Does anyone know of any devices that can switch 3kV to 10kV at very low currents (500uA-ish) that isn't the size of a single family dwelling with a doghouse in the back? I am trying to put it inside of a reasonably sized enclosure and the only switches I seem to find are Heavy Duty Electrical panel types (way too large).
My thoughts are to use something SPDT with the pole is the output, Throw 1 would be like 3000VDC, Throw 2 would be -3000VDC and select between the two. Anyone know of any good options?
Thanks!
EDIT:
Switching it while the high voltages are present is not going to occur. The goal is simply to get both polarity options to a single SHV connector without disconnecting the cable.
ronsimpson
Joined Oct 7, 2019
4,790
I have HV load boxes that are to test 40kv power supplies. I can program them for 1mA load that switches on and off some rate. Inside the switch is a tube. I don't know the part number from memory. There is one option.
4500V MOSFET I have and use MOSAFETs up to 4500V. I have stacked 2 or 3 transistors to get higher voltage.
The IGBTs I have at 4kv and 4.5kv are 200A and larger.
Sanyo and OnSemi make 1500 and 1700V transistors but the current is low.
I have some 5kv reed relays and can fine 30 different types for 10kv.
Metalfan1185
Joined Sep 12, 2008
185
Wow I didn't know they made MOSFETs that go up that high in voltage! Looks like some switching scheme using individual reed relay switches may be best for my application. Thanks!
