Switching circuit error
ashokchandra
Joined May 13, 2018
37
Hi ,
i am implemented Switching circuit for 50V@10A .and i am controlling on and off by micro controller.but i am getting 50V@2A maximum.
and let me know what should i change in below attached circuit to get 50v@10A.
Thanks,
Ashok
bertus
Joined Apr 5, 2008
23,031
In the configuration you have now, the gate voltage will be 2/3 X 50 Volts = 33.33 Volts, wich will exeed the mosfets specs.
Exchange R1 and R2 to get 1/3 X 50 Volts = 16.666 Volts.
Bertus
ashokchandra
Joined May 13, 2018
37
Bertus
In the current values what i implemented in circuit i am getting gate voltage of 16.66V. if i exchange the resistor values i will get 33V at gate.
Thanks,
Ashok
AnalogKid
Joined Aug 1, 2013
12,297
That is the voltage from the gate to GND. But you are using a p-channel MOSFET, with the source tied to the 50 V. The correct measurement always is from the gate to the source. Follow Bertus' advice.
ak
ebp
Joined Feb 8, 2018
2,332
How can you possibly get 50 volts and 2 amperes across the load?
If what you are saying is that the supply is 50 V and the current is 2 A, then that is possible, but it also means that with a 6 ohm load the voltage across the FET will be 38 volts and its dissipation 76 watts, which will cause it to heat to high temperature very quickly unless it is on a good heatsink - and given that is is a surface mount package that is next to impossible. On one square inch of foil the predicted die temperature would be 3800°C! (50°C/W)
Sensacell
Joined Jun 19, 2012
3,789
Here is a much simpler way to do it.
The NPN acts as a current sink, it sinks about 1.2 mA, which gives you about 12V Gate to Source, over the gate resistor.
Works as long as the supply voltage is over about 15 volts.
