Switch mode power supplies in parallel to generate 6A output current(from 12V-24V dc battery)
Bhargav Jani
Joined May 20, 2016
114
Hello ,
Need your suggestions, I plan to design a circuit (switch mode voltage regulator )DC\DC converter
The input to the smps circuit is from a battery Vbat (12V-24V) for automotive applications
The aim is to have Vin from (12V-24V) and to have output current upto 6A ..'
The control to the circuit has to be from a micro controller.
The ECU (electronic control unit) of a vehicle is also in the picture which will have input from the V(batt)
Aim is to have communication between the micro-controllers of may be 2 or 4 Switch mode regulators in order to get the output current upto 6A ..
Suggestions welcome
AnalogKid
Joined Aug 1, 2013
12,298
Your requirements are missing some things:
Are these to be constant-voltage regulators?
If so, what is the output voltage from the regulators?
Is the output voltage to be adjustable over a range?
Or are these to be constant-current regulators?
If so, what is the output voltage compliance range?
Is the output current value to be fixed, adjustable over a range?
"The control to the circuit has to be from a micro controller."
Why?
ak
Bhargav Jani
Joined May 20, 2016
114
The voltage range has to be from (12V to 48V ) nominal voltage
it can be adjustable depending (equal to Vin) or (less than Vin)
At the output, output current must be in the range (5A-7A)
Micro-controller will have CAN interface to communicate with ECU and other micro-controllers
As attached in a diagram, the design shall be something like this ...
The voltage from Vbatt cannot be given to the micro-controller and other ECU'S
